TwinTurbo.NET: Nissan 300ZX forum - hopefully the keyway in the crank snout isn't mangled
aliaZ
on October 09, 2014 at 5:32 AM
crankshaft pulley is disconnected
posted by Devonz32
on October 04, 2014 at 02:58 PM
I've seen crankshafts where the keyway was welded and remachined
Devonz32
14:58:09 10/04/14
Hope you need this:
-Grimm-
15:09:42 10/04/14
I just noticed the bolt that holds it on is off
Devonz32
15:27:41 10/04/14
Suggest you remove belts and pulley and inspect everything
ZXoltan
15:59:36 10/04/14
Re: Suggest you remove belts and pulley and inspect everything
Devonz32
16:09:14 10/04/14
Front oil pan seal?
-Grimm-
18:39:37 10/04/14
hopefully the keyway in the crank snout isn't mangled -
aliaZ
05:32:36 10/09/14
